1998 Saturn SL2
1998 SATURN SL2
FERD TRENKAMP
Electrical problem
1998 Saturn SL2 4 cyl Two Wheel Drive Automatic 120k miles
I have a problem with my sl2 ,using an electronic timing light I am able to only show it firing on #2 & #3,#1do not show any sign of energy in #1 -#4 plug wires .
I have replaced the plugs,plug wires & valve cover gasket because there was oil build up around plugs,this made it run better but not good enough ,still no sign of fire at 1 & 4 ,I tested the coils and they both tested OK on secondary ,replaced coil on 1 &4 -no change .Before I spend any more money I want to know what to check next?
Ferd
Apr 9, 2010 at 12:59 PM
SATURNTECH9
  • 30,869 POSTS
I have worked for Saturn repairing them over 16yrs never used a timming light to check for firing.do u have a dead hole rough idle what is ur concern ur having do u have any codes if u have a missifire it will set a code for that.let me know.
Apr 10, 2010 at 2:56 AM
