ABOUT TWO DAYS AGO MY CAR RAN LOW ON OIL THE OIL LIGHT CAME ON THEN THE COMPUTER SHUT IT OFF. SO I TOWED IT HOME AND TOPPED THE OIL OFF. THEN IT STARTED KNOCKING. WE DIAGNOSED IT AS A ROD BEARING. SO I REPLACED ALL FOUR BEARING. CYL 2 ROD BEARING WAS BAD AS WE THOUGHT. THE CRANK WAS NOT HARMED BEARING WAS STILL THERE AND DIDNT TURN JUST ABOUT THERE THOUGH. NOW AFTER ALL THAT. I STARTED THE CAR AFTER REPLACING THE BEARING KNOCKING CAME BACK AGAIN AND ITS FROM THE CRANK BECAUSE IT GETS LOUDER WITH HIGHER RPM'S.
Jul 15, 2010 at 9:34 PM
