1992 Saturn SL2 starting
DRYDOC7
  • 1992 SATURN SL2
  • 4 CYL
  • MANUAL
  • 260,000 MILES
Using digital multimeter set at 20 M, clutch in 9.41, clutch out 19+
Wednesday, June 30th, 2010 AT 9:29 PM
Hi drydoc7, Welcome to 2carpros and TY for the donation
If you're referring this clutch as the clutch switch-specs is unknown at this time -remove the wiring connector-read the switch should read infinite and when depressed should show a reading bcuz its going across the contact of the switch plus the wire resistance.
If you jumper the connector and it starts up the problem is the clutch switch irregardless of the readings. Make sure its adjusted properly
Wednesday, June 30th, 2010 AT 10:09 PM
