I have a 1992 Saturn SL2, 1.9L dohc that starts fine, runs fine, then after ten minutes or so stalls without warning. Sometimes it will start right back up, but lately it takes longer and longer to start, sometimes 30 minutes to an hour. Problem is getting worse. I bought a fuel filter (to my knowledge it's never been replaced). Do you thimnk it is indeed the fuel filter? If yes, is the little plastic thing that comes with the filter the tool for disconnecting the line? Also, could it be a map sensor?
SPONSORED LINKS
Wednesday, March 31st, 2010 AT 7:22 PM
