overheating and thermostat
150,000 MILES • 4 CYL • FWD • AUTOMATIC
AFIELD1984
i would like to know how to replace my thermostat and also how to get better acceleration from my car and better gas mileage.
Sep 20, 2010 at 9:44 AM
SATURNTECH9
  • 30,869 POSTS
So your car over heat's?How high does the temp gauge get?Does your cooling fan come at just over half way on the temp gauge?It's most likely not your thermostat they usually stick open not closed.The most common reason's for over heating on those car's are bad cooling fan motor coolant leak or a bad coolant temp sensor.How do you know it's overheating?Is it boiling over the cap or reading in the red on the temp gauge?Let me know so we can figure this out.
Sep 20, 2010 at 10:54 AM
HARRY321
Mine keeps overheating. It helps if I have the heat on full blast but the coolant does boil over every time. And I do think there’s a leak in the coolant. Should I replace the thermostat to help with the overheating.
Sep 13, 2019 at 2:56 AM
  • 55,694 POSTS
If the system is low it will overheat here is a guide you can look through which shows you how to find the leak.
https://www.2carpros.com/articles/car-is-leaking-coolant
This guide can help as well
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Sep 16, 2019 at 3:54 AM
HARRY321
What will cause the coolant to boil and steam from the housing Everytime I drive
Sep 16, 2019 at 9:25 AM
This is caused by the engine actually overheating. There isn't one reason for an overheat. This is the same guide that Ken gave you previously. Give it a read to familarize yourself with the causes. It could be the thermostat but if you have a leak, that needs to be addressed first. You can pressure test it and that should cause the coolant to come out of where it is leaking to help identify it.
Once you look this over, let us know where the leak is and we can help fix that first. Once the system is full and not leaking I would start looking at a head gasket issue just to make sure that is not the issue. If it is then we will need to go in a completely different direction. That may not have been the original cause of the overheat but when an engine overheats repeatedly the heads warp. If that happens the overheating is no longer the biggest issue.
Sep 19, 2019 at 12:17 PM
