2002 Saturn SL1
220,000 MILES • 4 CYL • FWD • AUTOMATIC
SCOOTER2888
I just replaced the front calipers and pads (both sides). I bled the brakes and topped up the fluid but now the brakes bottom out. When I press hard to the floor the brakes skid. Do I need to bleed them again, I must be missing something.
Aug 9, 2010 at 7:46 AM
SATURNTECH9
  • 30,869 POSTS
If you bleed all the air out of your brake's to make the make pedal firmer you need to clean and adjust your rear brake's.That will make all the difference in the world.
Aug 9, 2010 at 7:55 AM
SCOOTER2888
thank you. I will do that tomorrow as I work outside and it is raining now.
Aug 9, 2010 at 8:24 AM
SATURNTECH9
  • 30,869 POSTS
If you haven't bled all four wheel's you going to want to do that.Before you adjust the rear brake's.
Aug 9, 2010 at 9:00 AM
