My daughter's transmission started giving her trouble a week ago. When she drives the car it runs fine for the first 20-30 minutes, but when the car engine and trans gets warmed up (normal running), she starts from a dead stop, the engine RPM increase and the trans wont shift out of first gear. The car will only run about 25 MPH. If it cools down it starts shifting again. Do I need to change the Valve Body? Or is it a bigger problem?
Please advise!
Thank You
SPONSORED LINKS
Wednesday, May 12th, 2010 AT 12:14 PM
