1997 Saturn SL1 Engine Stutters and Sputters when accelerat
1997 SATURN SL1
116,000 MILES • 4 CYL • FWD • AUTOMATIC
SAEZZO
Wjhen pressing on the gas, the engine will stutter and sputter. It seems to lag.
Dec 14, 2009 at 5:31 AM
SATURNTECH9
  • 30,869 POSTS
so when ur concern happens does it feel like the engine is missing?does it happen when cold or both when cold or hot only when hot gets worse the hotter it gets?is it worse with a/c on?any codes let me know.
Dec 14, 2009 at 6:22 AM
SAEZZO
It does feel like the engine is missing. This happens all the time no matter hot or cold. And the A/C currently does not operate. There are no codes that come on when this happens.
Dec 14, 2009 at 8:02 AM
SATURNTECH9
  • 30,869 POSTS
Sounds like u might need plugs an wires inspect ur spark plugs for wear also on ur coil pack remove ur spark plug wires one at a time and put it back on then move to the next one that way u don't get the wires mixed up see if any of ur coil towers have white powder on them.let me know what u find also look for black powder on the end of the plugs where the wires go on and in the spark plug boots.
Louie
Dec 14, 2009 at 8:33 AM
