1995 Saturn SL1 cooling fan
STEWMAN_28562
Engine Cooling problem
1995 Saturn SL1 4 cyl Automatic 211068 miles
on my 1995 saturn with 211068 miles, my engine cooling fan does not come on. i checked the 30 amp fuse and its good. i pulled the plug from the fan and tested the plug but nothing. what could be causing this problem and how can i repair it?
Jan 8, 2009 at 8:43 AM
DOCFIXIT
  • 18,828 POSTS
Under hood in relay box find cooling fan relay I believe there are two swap them. Do you have AC ? if yes turn on do fans come on? also there is a temp sender that senses when to turn fan on.
Jan 2, 2020 at 11:58 AM
