I have a 1995 saturn sl1 and I just did a head job on it and it went great car runs good. But when I turn on my air conditioner its works fine until I put the car in gear and then it starts kocking until I give the car some gas and then it gos away until I stop. Why would this happien. Thanks james
SPONSORED LINKS
Friday, July 30th, 2010 AT 7:50 PM
SATURNTECH9
MECHANIC
What's knocking the A/c compressor or the engine?
Friday, July 30th, 2010 AT 7:58 PM
LADAGE22
MEMBER
I dontknow I think its the engine could it be the comperssor
SPONSORED LINKS
Friday, July 30th, 2010 AT 8:44 PM
LADAGE22
MEMBER
I dont know I think is the engine the ideling speed drops from 700 rpm to 500 rpms when I put the car in drive
Friday, July 30th, 2010 AT 8:46 PM
SATURNTECH9
MECHANIC
So if the a/c isn't on does it knock in gear?Also can you hear any squealing noise like the belt squealing when you hear the knocking and hit the gas and it goes away?
Friday, July 30th, 2010 AT 9:50 PM
LADAGE22
MEMBER
The belt is new and its like a knock from the engine or
transaxle. No if the ac is not on it does not make the nosie in gear.
SPONSORED LINKS
Friday, July 30th, 2010 AT 10:37 PM
SATURNTECH9
MECHANIC
Your going to have to be under the hood and listen for the knocking noise while someone start's the car and put's it in gear with the a/c on. It sound's like it's the belt tenisor or the a/c compressor knocking.
