1994 Saturn SL1 Over heating
KARLIY
  • 1994 SATURN SL1
  • 4 CYL
  • FWD
  • MANUAL
  • 180,000 MILES
I have a 94 saturn that likes to over heat.I don't know if the fan is or isn't coming on. But driving around with the heater FULL blast isn't working for me anymore.. The engine coolant container is full and the thermostat is fine. Please help. Its too hot!
Wednesday, May 26th, 2010 AT 7:12 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If coolant level is full and tstat is good then you need to make sure radiator fan is coming on properly. If it is then have water pump inspected.
Wednesday, May 26th, 2010 AT 7:15 PM
KARLIY
  • 5 POSTS
I don't know if its coming on when its hot. But it comes on when the A/C is on which makes sense.
So I should turn on the car wait til it heats up and see's if the fan comes on. Now what happens if it doesn't come on?
Wednesday, May 26th, 2010 AT 7:18 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes and if it does not come on when it reaches operating temp. Then the coolant temperature switch is most likely faulty.
Wednesday, May 26th, 2010 AT 7:21 PM
KARLIY
  • 5 POSTS
Oh joy. So. How hard is it to change that switch?
And. Is there an easy fix to this. Until I can get under it with someone who knows more than I do?
Wednesday, May 26th, 2010 AT 7:24 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The easy fix for overheating vehicle would be if the thermostat was bad or coolant low. You said neither of these exist so there is no easy fix at this point. The coolant temp. Sensor is on the rear of the engine, near the coolant outlet
Wednesday, May 26th, 2010 AT 7:29 PM
KARLIY
  • 5 POSTS
Well damn. Thank you. Could it possibly bew the relay for the fan
Wednesday, May 26th, 2010 AT 7:32 PM
BLUELIGHTNIN6
  • 16,542 POSTS
No, if relay was bad then fan would not come on with the A/C.
Wednesday, May 26th, 2010 AT 7:33 PM
KARLIY
  • 5 POSTS
Darn. Ok. :(
