1994 Saturn SL1 Choke?
FLUF
  • 1994 SATURN SL1
  • 4 CYL
  • FWD
  • 10,000 MILES
What would cause my car to have a problem when it first starts cold? After it is warm it starts like it should. When the engine has been sitting and it is cold, it seems like it is over choked and floods very easily. I can't give no gas to start it or it will flood it. Even after it starts it runs very rough for about the first 15 to 30 seconds. Like it is to rich. It has a computer, so it is all electronic controlled, I don't see anyway to make any adjustments. I have no check engine light that comes on, to lead me to believe that it might be a sensor.
Once it is running for about a minute, it seems to run fine. It still is getting 20 to 22 mpg. I tried spraying choke cleaner around the intake to look for a manifold leak, to no evail. Looked for any kind of vacumn leaks on hoses, changed plugs, changed idle control selonoid.
I'm stumped, and can't afford the car dealer, any suggestions?
Thursday, December 31st, 2009 AT 6:25 PM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the doantion .. much apreciated
FUEL CONTROL
The PCM, using input signals, determines adjustments to the air/fuel mixture in order to provide the optimum ratio for proper combustion under all operating conditions. One of 2 types of fuel control systems are used: throttle body injection or port fuel injection. These systems can operate in the "open loop" or "closed loop" mode. Description of these modes is as follows:
Open Loop
When engine is cold and engine speed is greater than 400 RPM, PCM operates in "open loop" mode. In "open loop", PCM calculates air/fuel ratio based upon coolant temperature and Manifold Absolute Pressure (MAP) or Mass Airflow (MAF) sensor readings. Engine will remain in "open loop" operation until oxygen sensor reaches operating temperature, coolant temperature reaches preset temperature and a specific period of time has elapsed after engine start-up.
Closed Loop
When oxygen sensor has reached operating temperature, coolant temperature has reached a preset temperature and a specific period of time has passed since engine start-up, PCM operates in "closed loop". In "closed loop", PCM controls air/fuel ratio based upon oxygen sensor signals (in addition to other input parameters) to maintain as close to a 14.7:1 air/fuel mixture as possible. If oxygen sensor cools off (due to excessive idling) or a fault occurs in the oxygen sensor circuit, vehicle will once again enter "open loop" mode.
Hope this helps
HAPPY NEW YEAR
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_930.png
Thursday, December 31st, 2009 AT 10:34 PM
FLUF
Is this telling me I need a PCM or an oxygen sensor? Should I have the Oxygen sensor tested? Can the O2 sensor or the Pcm be tested? My mechanic made a comment about the electric fan running alot recently, could this have anything to do with my problem?
Friday, January 1st, 2010 AT 9:30 AM
DAVE H
  • 13,384 POSTS
Both O2 and PCM can be tested !. If the coolant temp sensor is bad/faulty (causing the fan to stay on) or the coolant level is incorrect. This could be your problem giving the PCM incorrect readings?
Friday, January 1st, 2010 AT 11:35 AM
