2002 Saturn SC2
2002 SATURN SC2
112,000 MILES • 4 CYL • FWD • AUTOMATIC
HAA99
On occassions I have problems with my car shaking while driving at higher speeds. When this happens, my car seems to lose power and struggles to go above 60 mph. The brake pedal also becomes stiff. Once I pull off the highway, it drives completely normal at speeds around 40-50 mph. At times, I can also smell a burning odor.
We had this happen one time within the first 15 minutes of a longer trip. We pulled off the road, restarted the car, were able to continue on with the rest of our 2 1/2 hour trip with no incidents.
It also seems that everytime this has happened has been when I haven't allowed my car to "warm-up" for a few minutes before driving. Outside temperature, however, seems to not be an influence. Any ideas?
Oct 16, 2010 at 9:27 AM
SATURNTECH9
  • CAR REPAIR CONTRIBUTOR
  • 30,869 POSTS
Do you have any code's?Also does your car have any problem's shifting to the next gear or starting?
Oct 16, 2010 at 10:55 AM
HAA99
I haven't had any problems starting the car although we did have to purchase a new battery about a month ago. It doesn't usually struggle to shift gears except occassionally on steep hills. No lights on the dashboard either. I used to have issues with the car leaking / consuming oil quickly where it would burn through the oil in about 3 months. A mechanic fixed this about 6 months ago, and I no longer get the low fuel light. The problem I currently have has been on-going for a few months, but it is sporatic.
Oct 16, 2010 at 12:14 PM
SATURNTECH9
  • 30,869 POSTS
So do you have any code's?Also when it's loosing power you will have to check fuel pressure and exhaust back pressure.Also have you ever changed your fuel filter?They get changed every 100,000 mile's on your car by then there really restricted.
Oct 16, 2010 at 10:52 PM
