1999 Saturn SC2 high rpm's
1999 SATURN SC2
158,000 MILES • 4 CYL • FWD • MANUAL
CRUDFOOT
What would make the engine in my Saturn not want to idle down when up shifting through the gears? I have taken the air breather loose from the throttle body and sprayed cleaner in there with not much of an improvement in performance.
Dec 14, 2009 at 12:05 PM
1999SATURNSC2
  • 11 POSTS
There is many things that can cause a high idol. Everybodys first thought is the throttle body. But half the time it is never that. But first off, watch how you shift. Never "run out" the gears is a good idea. Shift out of first at a lower rpm.
Before anything, get dyno codes! That will tell you exactly what is wrong.
Aug 5, 2010 at 8:41 AM
