1996 Saturn SC2 Headlight Motor
1996 SATURN SC2
124,000 MILES • 4 CYL • 2WD • AUTOMATIC
WHODEYDIVA
The hidden headlights on my 96 Saturn SC2 go up and down perfectly, but the motor assembly on the right side makes a terrible noise until they are raised back up...Do I need to replace the entire assembly or is there an easier fix?
Jun 7, 2010 at 12:06 AM
SATURNTECH9
  • 30,869 POSTS
If the motor keep's running when the head light door is closed then you need a new motor sorry for the bad new's.If you have anymore question's let me know.
Jun 7, 2010 at 6:10 AM
WHODEYDIVA
Makes noise for about 10-15 sec other than that have had no problems opens and closes normal...just for a few seconds makes that excrutisting noise. I also lubed the whole assembly with WD-40
Jun 7, 2010 at 7:47 AM
SATURNTECH9
  • 30,869 POSTS
The motor is going bad i have seen that problem before you can change the motor or live with it till the motor die's.
Jun 7, 2010 at 8:40 AM
