1991 Saturn SC2 O Rings or valve cover gasket?
1991 SATURN SC2
JEREMYPARKER77
Engine Mechanical problem
1991 Saturn SC2 4 cyl Two Wheel Drive
I have oil in my spark plug and I need to know if I can just replace the o rings or do I need to replace both?
Jul 12, 2010 at 12:43 AM
SATURNTECH9
  • 30,869 POSTS
I would replace both the outer gasket and the gasket's around the spark plug hole's.I recommend the felpro permadry rubber gasket set.Auto zone sells them and probably others do too.I used one on my sister's saturn SL1 and like it better then the factory silcone glue in one.Much nice fit and a lot less chance of the gasket popping out.
Jul 12, 2010 at 5:26 AM
