2001 Saturn SC1 My saturn sc1 will not turn over sometimes.
2001 SATURN SC1
16,000 MILES • 4 CYL • FWD • MANUAL
WINERS
I have a 2001 Saturn sc1 just bought so i do not no the history it has 287000km, i just cleaned all the throttle body, replace ETC. Now sometime it will not turn over at all , all the accessory work, fuel pump comes on, has a new battery, i am a first year apprentice so i know some stuff this has me stumped, it does not click or make any nose i took out the floor mat to insure floor mat not holding the clutch forward today i had to push start it, then when i got home shut it down, and started after it has happened to me 3 times now and cant figure it out, Thanks.
Apr 10, 2010 at 11:35 AM
SATURNTECH9
  • 30,869 POSTS
So when the car is hot and u try to start sometimes the starter won't spin the engine over?no clicking from the starter even.if that's the case sounds like u have a bad starter.when it does it again u will have to make sure u have power to the little purple wire to ur starter solindo when u turn the key to the start postion.also make sure ur battery cables are clean and tight.no security light or anything like that when it doesn't start?let me know if u have anymore questions.
Apr 10, 2010 at 3:25 PM
