1999 Saturn SC1 code p0732
1999 SATURN SC1
103,000 MILES • 4 CYL • FWD • AUTOMATIC
DCJOSH
code p0732 came on. The code reads incorrect second gear ratio. I flushed the transmision fluide and changed the filter. The code went off and when I was test driving it the code came back. Is there any way I can fix it with out tacking it in to the shop?
Jan 2, 2010 at 5:01 AM
SATURNTECH9
  • 30,869 POSTS
Honestly it's best to take it to a pro unless u have the proper tools and knowledge to repair cars and transmissions.with that code u probably ethier have a leaking second gear piston in the transmission or a pressure issue in the trans like the pressure regulator in the valve body.let me know what u find and if u have anymore questions.
Jan 2, 2010 at 6:57 AM
