My Saturn had it "check engine" light on and is idling very fast (2500rpm). After mechanic did tune up, said this problem required replacing the current intake manifold gasket to make it run right. Is this correct ? What else could it be? Or will the problem be solved by simply replacing the fuel filter ? Thanks for your advice.
Apr 16, 2010 at 2:33 PM
