Help with 96 saturn
1996 SATURN
J REDNECK
  • 5 POSTS
Working on a friends 96 saturn 1.9 and there is a load knocking sounds like it is coming from timing chain housing. is it posible that there could be slack with out jumping time.it also has a rough idol and a spudering acceleration they had it at another mech. and he checked the coil packs and said they tested fine because there is no fire on two cylenders. alot of problem but alittle advise would be helpful thanks.
Jan 1, 2007 at 1:32 PM
SERVICE WRITER
  • 9,123 POSTS
Maybe worn guides or weak tensioner. NOt positive but I think the tensioner relies on oil pressure. Again not positive.
Jan 1, 2007 at 1:44 PM
J REDNECK
  • 5 POSTS
so would low oil pressure cause it not to apply the proper pressure if that is the case, leting it slop around
Jan 1, 2007 at 1:59 PM
SERVICE WRITER
  • 9,123 POSTS
IF I am correct about the tensioner, yes. I may be confusing this with the ecotech Motor? Maybe a guide worn out as well. Regardless if you go in there, I would always replace the tensioner if any other parts are replaced in the timing chain area. Just cheap insurance.
Here is a link that may help:
http://autorepair.about.com/library/a/1h/bl811h.htm
Jan 1, 2007 at 9:45 PM
