97 saturn SL-1
1997 SATURN
DEASONSBIZ
1997 Saturn SL-1, 1.9l SOHC, A/C, Manual Trans, 81K MI
Engine was running fine, then started to loose power. Downshifted to try to catch it, but it kept slowing, and then quit. No strange noises. Car will start and run for about 10sec then stop. Opening the throttle, causes it to stop immediatly.
Compression check-all cyl even at 180psi, plugs firing normal.
Plugs are clean
No codes
Ideas on what to check next or most likely cause?
May 23, 2007 at 11:19 PM
SERVICE WRITER
  • CERTIFIED EXPERT
  • 9,123 POSTS
Have you checked fuel pressure?
May 24, 2007 at 5:19 AM
