2000 Saturn failing emission inspections
2000 SATURN
FIT42007
My car has failed 5 emission state inspections. I have a 2000 Saturn, sc coupe, 4 cylinder, 94,000 miles. The service engine light kept coming on and they kept telling me to drive it some more which I did. The light finally went off and hasn't been on since I've driven it 1000 miles. The last inspection gave me 3 codes: Catalyst not ready, EGR System not ready and 02 sensor not ready. I am getting ready to take it to the Saturn Dealer but don't want to get ripped off. Can you help me?
May 30, 2007 at 11:48 AM
2CARPRO JACK
  • 11,533 POSTS
what you said arent really codes, they are the monitors in the PCM, and whether or not they are ready.It has been 1000 miles and no check engine light? If it passes out the tail pipe, it should be ok. Might want to find someone to pretest or scan the PCm to be sure all monitors are ready and the tail pipe readings are good. Have all 5 fails been due to the same thing (monitors not reseting or being ready) ?
May 31, 2007 at 12:58 AM
FIT42007
Yes, it's been the same messages with each inspection. How much does it cost to fix it so it will pass the inspection. Unfortunately, I don't know anyone with a scanner. thanks
May 31, 2007 at 2:58 AM
2CARPRO JACK
  • 11,533 POSTS
If the monitors dont reset, then you probably have other problems
May 31, 2007 at 10:39 AM
FIT42007
Okay, took it to the Saturn dealer today. They said that the EGR Valve needs replacing ($300) and the Thermostat Sensor reads out of range ($489).
Jun 1, 2007 at 4:44 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds ok except what is a thermostat sensor?
Jun 1, 2007 at 10:14 AM
SERVICE WRITER
  • 9,123 POSTS
Since there aren't codes setting, but monitors (powertrain management self-tests) not running like Jack says, I don't see why the egr should be a problem. I have seen coolant temperature sensors be bad causing the computer to get faked out thinking a self-test should be able to run when in fact the sensor was giving the computer an incorrect temperature of the coolant, allowing a monitor to run at the wrong time. I am having a hard time understanding the logic. Also like Jack, I never heard of a thermostat sensor.
Jun 3, 2007 at 10:55 AM
FIT42007
I'm probably saying it wrong. The mechanic said that the thermostat sensor reads out of range. It reads hot. My car over heats when I am in traffic standing still. (another problem that I am having)
Jun 4, 2007 at 3:48 AM
