Noises problem
1992 Other Saturn Models Engine Size unknown Front Wheel Drive Manual 300000 miles
I am having a major problem with the Saturn. We have replaced many things on this car, the clutch, the muffler, the front and rear brakes, both front axles, both wheel bearings, and the water pump. some of those were because the shops kept giving us estimates saying that the bearings were out or what have you and that was causing the noise....It's an extremely loud clunking/rubbing noise that sounds like it's coming from under the floor boards near the passenger side in the front. The noise has gotten worse and worse as we have tried to fix it, and now it's so bad that at times the whole car will be shaking. If you can tell me what we should generally take a look at that would be great!! Now, bear in mind that we got both of the axles from the junkyard...so maybe one of those was bad? plz help! thanks!!
Mar 29, 2008 at 2:56 PM
