2003 Saturn L200 A/C blows hot air and then the temperature
93,700 MILES • 4 CYL • FWD • AUTOMATIC
PAKSAK
The engine on this vehicle was replaced in 2008, but the car mileage is 94000 roughly. About a month ago, the A/C was on - it was 100 degrees outside, the A/C started blowing hot air and then the temperature gauge went from normal to hot in less than 60 seconds. What is the issue and approximately how much is the part? Thanks!
Oct 4, 2010 at 7:10 AM
SATURNTECH9
  • 30,869 POSTS
It's not that easy to come up with an answer especially over the internet.The two could be related if the engine get's hot enough the a/c pressure could get high enough to shut the compressor down.Most likely what happens in that case is the cooling fan is not working correctly.So are your cooling fan's working you have two one for the radiator and one for the a/c.Also do you have any trouble code's?Do you have auto climate control or manual a/c.Let me know what you find.
Oct 4, 2010 at 7:34 AM
PAKSAK
According to AutoParts Now that ran a diagnostic, there were no trouble codes. It was this gentlemen's impression that the cooling fan was shutting down which was causing the temperature gauge to run hot. Any help is greatly appreciated.
Oct 6, 2010 at 1:33 AM
SATURNTECH9
  • 30,869 POSTS
So do you have auto climate control or not?Also does the Radiator fan come on just past half way?
Oct 6, 2010 at 2:56 AM
PAKSAK
No auto climate control that I am aware of...
Oct 11, 2010 at 1:32 AM
SATURNTECH9
  • 30,869 POSTS
So does your radiator cooling fan come on just after half way on the temp gauge?We need to start there that" the first thing i would check.Let me know what you find.
Oct 11, 2010 at 5:46 AM
