2002 Saturn L200 wheel sound
78,530 MILES • 4 CYL • 2WD • MANUAL
BLOODTIGER
  • 6 POSTS
There is a sound coming from the front passenger wheel, Replaced brake pads and didn't help. While replaceing pads I checked for a bad wheel bearing and cv joint both seemed fine, wheel not abnormal loose or tight the cv joint had a little oil on it but otherwise the simple test of shaking the wheel seemed to produce nothing wrong.
Jan 12, 2008 at 8:40 AM
MASTERTECHTIM
  • 4,750 POSTS
does the noise change when you turn from left to right while driving down the road. let us know.
Jan 12, 2008 at 8:58 AM
BLOODTIGER
  • 6 POSTS
no always on passenger side while driveing starts up a couple of seconds in to drive and stops when stopped
Jan 12, 2008 at 10:14 AM
BLOODTIGER
  • 6 POSTS
I am wondering if the anti-lock brrakes or traction control has something to do with it, Its my wife's car so I don't drive it often.
Jan 12, 2008 at 10:18 AM
BLOODTIGER
  • 6 POSTS
I did have some abnormal wear on brake pads but Not to off
Jan 12, 2008 at 10:19 AM
MASTERTECHTIM
  • 4,750 POSTS
no not abs. i know the noise is on the pass side. does the noise change in sound when driving down the road and turning left to right. like get loud then soft...
Jan 12, 2008 at 10:32 AM
BLOODTIGER
  • 6 POSTS
as I accelerate It changes in pitch to a point then stays makes no difference turning right or left
Jan 12, 2008 at 10:34 AM
BLOODTIGER
  • 6 POSTS
sounds sorta like a squealer on the pads witch is why I replaced them
Jan 12, 2008 at 10:37 AM
MASTERTECHTIM
  • 4,750 POSTS
i was asking you if it changed going left to right because if it did then you would have a bad wheel bearing but that does not appear to be the case. it sounds like you have a bent backing plate that is hitting the rotor. try when you have the front end of car on jack stands remove pass wheel and reinstall lug nuts to rotors to keep it straight then rotate the rotor to try to duplicate the noise. you might see the metal backing plate touching the rotor. then just bend it away.
Jan 12, 2008 at 10:45 AM
