2002 Saturn L200 evap emission system malfunction
2002 SATURN L200
97,673 MILES • 4 CYL • AWD • AUTOMATIC
MIZZARIES
could you please explain to me so i can understand
what my diagonostric read with my service engine
soon light.The reading came up PO440-EVAP
EMISSION SYSTEM.what on earth does this mean
and how serious. thankyou
Sep 21, 2009 at 9:40 PM
SATURNTECH9
  • CAR REPAIR CONTRIBUTOR
  • 30,869 POSTS
that code means you have a leak in your fuel system the engine pulls a vaccuum on ur gas tank etc removes all the air when your ecm closes the system off then monitors the amount of leakage it has and if it has a leak then it will flag a code.it could be a simple as a bad gas cap remove your cap and inspect the seal if the seal is cracking then replace it.also could set that code if the cap was loose.also could be a leaking fuel pump oring cracked or leaking line etc.bad fuel tank pressure sensor.its best to have a professionial look at it.hope this helps.
louie
Oct 2, 2009 at 5:04 PM
