2002 Saturn L200 AC doesnt not work
KENANDAMME
  • 2002 SATURN L200
  • 4 CYL
  • FWD
  • 87,755 MILES
What is wrong with my AC? I have replaced the fuse and did a recharge on it and still does not work. Nothing seems to turn on, just blows out hot air. IS there something I am not thinking of or is it my compressor or clutch for the compressor?
Monday, May 5th, 2008 AT 7:56 PM
  • 31,937 POSTS
Hi there,
first thing to do is get the system pressures tested. This will give the tech a better idea as to what is going on, do this first.
Mark (mhpautos)
Tuesday, May 6th, 2008 AT 1:20 AM
MRBOGEY
I found this on a google search. I have a Saturn LS1 giving me the same issue. I checked the pressure on the line and it's actually high. I tried pulling the 40amp HVAC Blower fuse and it keeps pumping hot air. When I check for ground continuity it gives me squat though voltage is flowing through the fuse.
When I do flip the AC to on it does cycle on the compressor though.
Does that help any?
Tuesday, May 20th, 2008 AT 6:50 PM
