Transmission problem
2002 Saturn L200 4 cyl Front Wheel Drive Automatic
I installed a used transmission and now all I have is 1st gear. It won't go out of 1st gear.
Sunday, October 24th, 2010 AT 2:52 PM
SATURNTECH9
MECHANIC
What was your old transmission doing?What code's do you have?Also what yr and model car did the used transmission come from?
SPONSORED LINKS
Sunday, October 24th, 2010 AT 3:28 PM
CHRISHOWELLS
MEMBER
The old transmission shifted but made bad clunking noise when putting into gear.
I don't have the code but the used transmission is from the same year and model
Sunday, October 24th, 2010 AT 3:45 PM
SATURNTECH9
MECHANIC
So it's from a 4cyl L model saturn?We need to get your code's read so we have a starting point on what's going wrong.
Sunday, October 24th, 2010 AT 3:58 PM
CHRISHOWELLS
MEMBER
Does it have to be programmed to the car? Why does it need the codes read?
Sunday, October 24th, 2010 AT 4:21 PM
SATURNTECH9
MECHANIC
I'm talking about trouble code's that are set in the computer to lead us in a direction to see why you only have one gear. You need to rent a scan tool and let me know what code number's you have.
