We have a two fold issue. When its raining, we have shut the vehicle down and sometiimes the fan stays running, while other times there is a black small box that we can hear a noise coming from. If we do not pull the fuse to stop either then they will run the battery down. Once the rain stops and drys out then the noise or the fan will usually stop shortly thereafter. We have concluded that it is reacting with the rains. This also happens sometimes in the winter but only if the snow is relatively a wet snow. After pulling the fuse and installing after a couple hours the noise or the fan usually stops but waiting short time like 15-30 minutes doesn't usually stop the situation. Please respond to rob@screenprintery.com
May 10, 2010 at 5:34 AM
