2000 Saturn L200 Power steering isnt pumping
2000 SATURN L200
75,000 MILES • 4 CYL • FWD • AUTOMATIC
KELLANDJOSHUA
I was Driving my car on day and the power steering gave out.. there is no leaks in the hoses and how i know that is because my fluid box in full of power steering still...
I need to know some of the reasons of why this happiand and if there could be a fuse that i would have to change if there is a fuse for the power stearing pump
Nov 2, 2008 at 6:08 AM
MO126CAV
the pump is not working. the pump is on top of motor run's off the cam on the drivers side. the shaft that go's into the cam is sheared off. remove the pump 2 or 3 bolt's then take a magnet and pull out the end that is still in the cam. the new pump is about $35.00 easy fix.
Jan 16, 2010 at 9:12 AM
