2002 Saturn L100 Car will start up run for 3 seconds &
2002 SATURN L100
76,000 MILES • 4 CYL • 2WD • AUTOMATIC
BRIANTYPHOON1
Car will start up run for 3 seconds & stops. If you turn the key but not all the way you can here the fuel pump comeon for about 3-4 second then turns off. Then if you turn the key to the start position it will start run for 3 seconds and then stop it does this every time. I was working with a guy who knows about cars IFirst he had me purchase a New Battery, then a new crank timing sensor???. The only other piece of important information I have is that the fuel gauhe does not work when you turn the key on. All the other gauges work except the gas gauge. I bought a Haynes manual, and it says it could be the Fuel pressor sensor, maybe the fuel level sensor, which I think is conected, or part of the fuel pump. Any guesses would be greatly appreciated. I don't want to have to replace a $350.00 fuel pump if it could be something small or less expensive, however because the fuel gauge doesen't work I think it may be the fuel pump... Thanks for the help..Brian
Jul 16, 2010 at 3:12 PM
SATURNTECH9
  • CAR REPAIR CONTRIBUTOR
  • 30,869 POSTS
Sounds like you could have a bad body control module really common for those car's.Gas gauge inop no start does your key less entry work?How about your door locks?With the key on can you take it out of park?Also does your interior light flash?Have you checked your fuse's.
Jul 16, 2010 at 3:21 PM
