2000 Saturn L100
2000 SATURN L100
79,930 MILES • 4 CYL • FWD • AUTOMATIC
JOAN P. HYER
cooling light comes on when I start the car. It stays on. checked the fluid. filled to the cold line.
Sep 5, 2009 at 10:13 PM
SATURNTECH9
  • 30,869 POSTS
theres two lights on there one for winshield washer fluid and the coolant one.if its the coolant one unplug the plug and jump the terminals and give it a few mins and see if the light clears if it does and you have a good connection at the bottle then you need a new sensor if it doesnt shut off then you have a circuit problem.also when you jump the plug make sure you cycle the key from run to off to run again start it and see if the light goes out after a few mins with it running.let me know how it goes.
louie
Oct 2, 2009 at 9:24 AM
