1992 Saab 9000 how come
1992 SAAB 9000
JAY10E
Engine Cooling problem
1992 Saab 9000 4 cyl Two Wheel Drive Manual
ok i have changed the thermost, water pump gasket, back flush the riadiader put new hoses on this thing and ill be drivin down the road all of a sudden it will be overheating then all of a sudden the temp gage flies down to cold then back up to hot agian and so on. also i change the cap to. if you all can help me out that would be so much
Jan 5, 2009 at 7:26 AM
DOCFIXIT
  • 18,828 POSTS
Any chance thermostat is in backwards? spring points to engine
Jan 5, 2009 at 7:33 AM
JAY10E
that was the first thing i that thought of so i checked that it was fine. anything else u think it might be
Jan 5, 2009 at 7:56 AM
DOCFIXIT
  • 18,828 POSTS
May have air in system is there a bleeder ? if not pull cap jack up front of car run till all air out.
Jan 5, 2009 at 8:00 AM
