1996 Saab 900 Dome Light Doesnt go Out
1996 SAAB 900
PCAVINESS
Interior problem
1996 Saab 900 4 cyl Two Wheel Drive Manual
After the car is started the center dome light stays on for a while even after you start driving. Its acting like one of doors isn't shutting completely but they are. This is particularly distractive for night driving.
Apr 21, 2009 at 1:45 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Is "door ajar" warning lamps on as well? If so then suspect faulty door ajar switch. These switches are found in the door jambs or inner door of each door and/or rear hatch. Try spraying some WD40 , or equivalent, into the door jambs to see if this temporarily fixes the issue.
Thanks for using 2CarPros.com!
Apr 21, 2009 at 2:08 PM
PCAVINESS
The door switches are on the post where the close latches are. Is there something else located in the door hinges itself?
Apr 23, 2009 at 12:33 AM
BLUELIGHTNIN6
  • 16,542 POSTS
No, the switch is what turns the dome lights on for door ajar. Lubricate the switch and see if it helps.
Apr 23, 2009 at 4:32 AM
