1989 Saab 900 Oil Light and Cigarette lighter constantly on
1989 SAAB 900
170,000 MILES • 4 CYL • 2WD • MANUAL
DIVALINK
After I had a new starter and battery installed, the oil light in the dash stays on when I turn off the engine. The cigarette lighter is on constantly also. So far I haven't had any other problems, but I would like those functions to turn off as they did before this installation.
I've already checked the fuses and I had a replace two, but the light is still on.
How do I solve this problem?
Thank You.
Apr 13, 2009 at 7:18 AM
KHLOW2008
  • 41,814 POSTS
Hi divalink,
Thank you for the donation.
When ignition is turned off, there should be no power to oil light and when it shows, it indicates a bad ground connection between the engine and body and/or battery. This would result in current using the oil switch as a grounding to complete a circuit.
I would suggest checking for loose or inefficient body grounding circuits.
Apr 13, 2009 at 9:03 AM
