2000 Saab 9-5 inner half shaft stuck in intermediate shaft
204,000 MILES • 4 CYL • FWD • MANUAL
DAN082482
Hi. I'm replacing both the cv half-shafts in my saab. The drivers-side shaft came out easily, but my problem is the passenger-side inner half shaft is stuck inside the intermediate shaft. My question is... if there is a clip that's holding it in or is it just stuck in there? ...and if it is just stuck, how would I be able to remove it?
Thanks.
- Dan
May 25, 2009 at 1:50 PM
DOCFIXIT
  • 18,828 POSTS
Hi
There is a small C-clip like on end of one that is out.. It is stuck put a pry bar between inter. shaft support and CV joint and pop it out.
Hope this helps
Thanks for donate
May 26, 2009 at 6:21 AM
