1999 Saab 9-5 Heads or turbo???
1999 SAAB 9-5
135,000 MILES • 4 CYL • FWD • AUTOMATIC
LILMISSARRIES
I have been replacing hoses on my SAAB to repair a vacume leak/ loss of power/ compression problem I have been having.
I took my car on a test drive yesterday then without warning smoke started to billow out the tailpipe w a loss of power then died. No sound.
I coasted back to my garage then restarted the car without any problems accept that it is still smoking and has water dropplets out the tailpipe. (white smoke)
I checked the oil=no water or milky residue
I checked the coolant level=tiny bit lower but still in range
I checked the coolant resivour for gas "bubbles" coming up=none
My Question is....how do I know for sure whether my heads blew or it is my turbo without have a compression testing guage? Is there anything else I can check or look for?
Aug 4, 2009 at 4:25 PM
MNTHNY4
  • 612 POSTS
remove exhaust catalytic convertor & check for oil residue in exhaust side of turbo ,also remove spark plugs & look if piston tops look wet ,if wet replace headgasket .sound like a gasket problem cause pressure to build up in cooling system .
Aug 29, 2009 at 1:58 PM
RICKMAR
  • 170 POSTS
Head Gasket "ABSOLUTELY" ...
I am 99.99% positive.
Sorry for the bad news.
Rick
Nov 12, 2009 at 1:55 PM
