2004 Saab 9-3 repair Question front end chirping noise
2004 SAAB 9-3
37,000 MILES • 4 CYL • FWD • AUTOMATIC
KENNETH SOGG
i bought a 2004 saab convertible in april of 08. after a few months i began to hear a chirping noise from the front end whenever i would go over sharp bumps. the dealer also heard it and they replaced both struts and the swaybar bushings and greased everything they could for two months it was quiet but now it has returned i cant think of anything else up there that hasnt been changed or greased any idesa thanks ken
Jan 10, 2009 at 6:59 AM
2CARPRO JACK
  • 11,533 POSTS
Try lubing the sway bar again and see if it goes away. Some manufacturers use a higher poly content bushing for better life and performance, but they are noisy. At least if you lube just the sway bar and it stops, you know where the noise is originating from and can try bushings if you want to
Jan 10, 2009 at 8:33 AM
