Running rough when cold
160,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
CHEVROLET 1988
The vehicle listed above is an xl model. It runs rough when cold like it has a bad misfire smooths out when warmed up and engine pulls down bad when waiting at a redlight like it's about to shut off.
Apr 1, 2022 at 10:18 AM
  • 110,248 POSTS
Does the low idle happen only when it's cold? Also, have you checked for engine vacuum leaks? If not, start with that first. Take a look through this link. It explains how to locate and repair an engine vacuum leak.
Next, by chance do you have a live data scan tool? If you do, let me know what the short-term fuel trims are when it runs rough. Also, before starting the engine for the day, see if the engine coolant temperature sensor signal indicates a temperature very close to the ambient temperature.
Apr 1, 2022 at 3:24 PM
