Running poorly, cutting out
287,000 MILES • V8 • 4WD
KIRK P JOHNSON
As it is warming up it runs more and more poorly. The speedometer starts jumping around, it will downshift repeatedly and even disengage and over rev. It is a problem that is getting progressively worse that I can barely go to the store 2 miles away and back. but warm or cold it always starts nicely.
Nov 21, 2019 at 5:57 AM
Good afternoon,
Are there any codes set?
I am concerned about the transmission. It sounds like it is coming out of gear. You may have a clogged filter in the pan.
How long since you changed the fluid and filter?
Nov 21, 2019 at 6:23 AM
