rumbling sound coming from evaporator
85,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
LOU WALLMAN
a rumbling sound comes from the evaporator what is going on?
Mar 16, 2019 at 2:13 AM
This is actually known as bubbling or gurgling noises and it is normally always due to air in the system. If you are hearing this in the dash area, then more than likely it is the heater core.
https://www.2carpros.com/articles/vehicle-bubbling-noise
What I would suggest is we start with draining and filling the cooling system and make sure there are no pockets.
This guide will give the detail needed to complete this.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Please run through this info and let us know what you find. However, I suspect this will be an air pocket so please let us know if you have questions. Thanks
Oct 4, 2021 at 7:05 AM
