Remove and replace torque converter
1,234 MILES • 3.5L • 4WD • AUTOMATIC
AB AUTOMOTIVEREPAIR TRANSMISSIONS
  • 107 POSTS
Anyone ever do one of these? Customer is looking for a quote and I found AWD about 14.1 hours (looking on NapaProLink for flywheel) Was hoping you could help me quote this properly at $100/hour rate. Thanks guys. You're always amazing help.
Mar 17, 2020 at 11:38 PM
Good morning,
I found the same at 14.4. The issue is this, when you replace the converter, I always replace the front pump bushing and seal especially if it is from a leak.
I would cover yourself by adding on some time if that is the case.
You are looking at $1,500.00 for labor and I would add 2 more hours for the seal.
Mar 18, 2020 at 12:14 AM
  • 107 POSTS
Thanks Roy. always a pleasure hearing from you. :) Stay healthy!
Mar 18, 2020 at 12:23 AM
You as well, my friend.
Mar 18, 2020 at 12:26 AM
