RPM's stay high after stopping but drop to normal after a while
2000 FORD FOCUS
165,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
ALEXV55
  • 43 POSTS
I am trying to diagnose problem with high rpm which only happens after I drive above 45 rpm.
Background is the listed above has a Zetec engine. The car had low idle problem, it would stall after to coming to stop. I started checking for vacuum leaks and found collapsed PCV hose. Also checked PCV valve and found it was sticking and then IAC check revealed zero resistance at motor terminal so that was replaced too. Idle is now fixed.
After the repair on test drive, it has high rpm problem. Car starts and runs fine until I take it above 45 mph. When I let my foot off the gas pedal, the car keeps going. When I stopping the rpm stays around 1,700, and then suddenly drop to its normal idle shifts down.
- I have checked throttle cable and it is not sticking.
- I do not notice any vacuum leak, sprayed propane and starter fluid, no change in rpm.
- Scanner reading shows throttle position 18% at idle and changes with throttle movement. While driving when I let foot off gas, it drops immediately to 18% indicating closed throttle.
- MAF is another story. At normal idle its at .2 lb/min. goes up and down as I give it gas and let my foot off. But MAF reading stays constant at 1.7 - 1.8 lb/min after I let go of the pedal after speeding over 45 mph. It stays at this number even when I come to stop, rpm shows around 1,700 and idle eventually comes to its normal reading suddenly as described above.
- STFT and LTFT both are positive at idle. While driving LTFT remains high, around +8, while SF fluctuates between as +1.6, 0, and - 2.xx.
- o2 sensor reading looks normal.
Do you have any guidance how to go about diagnosing the problem?
Aug 27, 2016 at 3:31 PM
RENEE L
  • CERTIFIED EXPERT
  • 1,260 POSTS
Yes, this engine had this problem. Once you fixed these problems the computer must relearn the engine which can take a while. The factory has a computer that can clear the adaptation which will fix the problem if you do not want to wait it out. Try clearing the codes anyway to see if that helps.
Aug 31, 2016 at 6:36 PM
ALEXV55
  • 43 POSTS
The problem was the new IAC I had replaced. Apparently this car is picky about the IAC valve and insists on OEM. Off the market from parts store do not work as mentioned in many threads on the net. I replaced it with the original Motorocraft and everything was fixed.
Jul 23, 2017 at 5:20 PM
  • CERTIFIED EXPERT
  • 53,872 POSTS
Nice work, we are here to help. Please use 2CarPros anytime.
Cheers, Ken
Jul 24, 2017 at 3:29 PM
HIALIEN13
RPM's too high (1,500) when the car is in drive and AC on, when AC off runs perfect. I have tried two new IACV, two TPS, MAF sensor, new PCV valve. Cylinder head done at machine shop. No vacuum leaks. Tested with a Snap On scanner and every thing looks fine. Do not know where else to look or test.
Jul 24, 2017 at 3:30 PM (Merged)
HMAC300
  • CERTIFIED EXPERT
  • 48,601 POSTS
Try cleaning the throttle plateon both sides with choke cleaner.
DAVEMAX69
Four cylinder front wheel drive manual.
My car has had this problem for about a year. Here is what I know: heat is a factor the car has to be warmed up about an hours drive time before it acts up. Outside temperature also plays into to it. If it is hotter outside then it speeds up the problem, all winter no problem. The car starts to rev when you are trying to stop you can have it out of gear clutch in or out it still will do it. You can knock it down sometimes by shifting to a higher gear it will rev between 2,000 and 4,000 rpm's but has gotten as high as 5,000 once. We have replaced the computer no luck their, clutch seems to be fine my mechanic is stumped. I have no dependable car. Can you offer any suggestions?
LEGITIMATE007
  • CERTIFIED EXPERT
  • 5,121 POSTS
Well, first I would check the throttle position sensor and after that the idle air control valve. Then MAP sensor if none of those, solve the problem.
SQUISHEDBUNNY
Seeing this was the first time I knew someone else shared my pain! So a bit of a backstory bought the car advertised as "good car for a mechanic" I am a new mechanic*A&P*, but I know my way around the engine and have a strong mechanically inclined brain so I took on the project for my son's first car. $350.00 for a 2000 Ford Focus Wagon SE, 2.0, DOHC, the interior still looks pretty decent. Turns out the engine threw a rod. Bought a $100.00 eBay special and got everything installed, fumbled through learning vacuum lines and testing sensors. The bonus is that the engine with the thrown rod had several new parts that the previous owner had thrown at it, so it was like having parts exchange for anything I deemed suspect. But once all the obvious easy things had been fixed or adjusted I still had a big problem. Press the gas and the car continued acceleration after I let off the gas pedal. At first, it only did it while the A/C was on then later it did it anytime. I researched and watched hours of videos to no avail, I was ready to pay the price of taking to the dealership for diagnostic. Stopped in to see them and understood right away they wanted to throw parts at it until it subsided, and I was not inclined to oblige. Determined to figure it out or watch the car go up in flames (joke). I started rechecking everything dealing with air flow through the intake and was quite settled somehow some way it was the Intake Air Control that was the culprit. So I removed it from the extremely hard to reach position it is in for the third time, becoming very efficient at it I might add, and examined it with disgust, wondering why it has caused me so much aggravation. To my surprise, I found the ticket to the promise land! Nowhere in anything I have read or watched has it mentioned the IAC having an adjustment screw! All that was left was adjusting it to make everything hunky dory. Now my sixteen year old can take possession of the car that will last for years to come, or until his first accident (the reason for buying a cheap first car).
Jun 13, 2018 at 1:23 PM
  • CERTIFIED EXPERT
  • 53,872 POSTS
Great addition to this thread! Please feel free to help out whenever you are on the site.:)
Cheers, Ken
Jun 13, 2018 at 2:54 PM
