1995 Other Rover Models please help:-)
1995 ROVER
91,000 MILES • 4 CYL • 2WD • MANUAL
GORDY220TURBO
how you doing,i'm having trouble with my car and i'm in two minds whether its the coil or the lambda sensor or a bit of both...i have replaced the ht leads,plugs,rotor arm,dizzy cap and coil and still the problem persists...i have very bad mpg..150 miles from 55 litres,the car shudders mainly in 3rd 4th and 5th,it backfires also and runs on 3 cylinders...its fine 50 percent of the time but the other 50 its a nightmare...i ran it with the lambda unplugged and it was alright,gave only a tiny shudder from a 25 minute drive...the brand new coil isn't bolted onto the body so wont be earthed properly but would it cause all of the above problems??...will be very grateful for any advice as i'm not really getting anywhere with various garages..thanks alot.all the best.G Fraser
Mar 29, 2010 at 6:42 AM
DAVE H
  • 13,383 POSTS
the coil needs to earthed correctly it will cause the problems your describing ..the lambda sensor has to be plugged in or the computer is getting false readings and will use more fuel .. have the vehicle plugged intoa diagnostic computer to retrieve any fault codes stored !
Mar 29, 2010 at 10:24 PM
GORDY220TURBO
many thanks for your quick reply...al get it earthed asap n see how she is..thanks again
Mar 30, 2010 at 6:03 AM
DAVE H
  • 13,383 POSTS
No problem .. please keep us informed of the outcome !
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_1100.png
Mar 30, 2010 at 11:49 AM
GORDY220TURBO
how you doing guys?...earthed the coil in its correct place this morning and the car is still shuddering when in low revs in mainly 3rd 4th and 5th the only upside being when coming up to a junction and put car into neutral the revs no longer drop right down and the car doesn't stall..cheers.Gordon
Mar 30, 2010 at 11:16 PM
DAVE H
  • 13,383 POSTS
check for vacuum line leaks on engine .. also have the catalytic convertor checked for blockages !
Apr 3, 2010 at 9:49 PM
GORDY220TURBO
tried to take the cat off n put a decat on it but bloody stubborn bolts made it difficult...so thats next on the agenda...got a new fuel filter too so al see how i get on with that n let you know..thanks for your input.
Apr 5, 2010 at 2:14 AM
