1995 Rover Metro brakes have stopped working
1995 ROVER METRO
80,000 MILES • 6 CYL • 2WD • MANUAL
MACKEMMOORE1
my brakes pedal started to go further down but was still braking then 1 night when i tried to brake there was just nothing there. tried topping up the brake fluid but still not much at all. dont really want to spend big money as its an old first car.
Dec 29, 2009 at 9:46 AM
OBXAUTOMEDIC
  • CAR REPAIR CONTRIBUTOR
  • 3,711 POSTS
When you topped off the brake fluid was it empty or way down?
Have you looked under the vehicle to see if there is any fluid puddles at any of the wheels or anywhere.
If there is a puddle under vehicle then most likely you have a broken brake line.
Dec 29, 2009 at 9:50 AM
MACKEMMOORE1
when i topped it up it was slightly down no puddles or leaks to be seen anywhere
Dec 29, 2009 at 10:00 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, then most likely you have a failed Brake Master Cylinder. Check out link below, describes replacing Master Cylinder.
https://www.2carpros.com/how_to/brake_master_cylinder.htm
Dec 29, 2009 at 10:04 AM
