2000 Rover 45 5th gear popping out
WIZARDOFWOZ
  • 2000 ROVER 45
2000 Rover 45 Manual 50000 miles
my w reg rover 45 keeps popping out of gear. What is the most likely problem?
Saturday, June 12th, 2010 AT 6:29 AM
  • 31,937 POSTS
Hi there,
weak or broken detente spring in selector, worn selector hub, transmission loose on engine, if it tends to pop out under over run, i.E. Throttle off down a slight down grade, normally a worn of defective synchro hub in the transmission.
Mark (mhpautos)
Saturday, June 12th, 2010 AT 6:40 AM
