1997 Rover 4 Series Adding a ham radio connection to the wi
1997 ROVER 4 SERIES
77,112 MILES • 4 CYL • 2WD • MANUAL
DAVEKH
Hi I have ham radio equipment which takes about 20amps on peak and normal car 12volt supply - but I don't know where to get the supply for it inside the car - or if there is an easy way to route the wires that come with the radio throuigh the bulkhead. Any ideas?
Many people risk using the cigar-lighter but I think its not really rated for that .
Thanks DAve
Apr 24, 2009 at 10:15 PM
DAVE H
  • 13,384 POSTS
The cigarette lighter is the easiest and safest (it has it's own fuse) option ...what other higher amp wire are you considering wiring it to under the bonnet/hood ??
Apr 26, 2009 at 12:06 AM
DAVEKH
I checked the wires going to the back of the cigar lighter - they might do the job, if the ideas I have below turn out to not work..
I have a radio which takes I believe about 21amps when its used to transmit (think CB but Not)
I'd really like to have a separate run from the radio direct through to the battery with separate fuse and kept away from the rest of the circuit to keep out noises from alternator. (I know I can filter this).
I've noticed that if I open the door I can see under the corner of the wing (they're bolt on) and then a route through to the underside of the bonnet then straight to the battery. I have found some armoured flexible tube to stop the wires getting chafed. This might give me the direct route to the battery.
Apr 26, 2009 at 12:55 AM
DAVE H
  • 13,384 POSTS
Your easiest option straight to battery is where the bonnet release cable goes through the firewall into engine compartment ... thread your wire through the rubber plug and route it to the battery .. again I advise fuseing it !!!! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_584.png
Apr 26, 2009 at 1:11 AM
DAVEKH
Thanks for the help - I'll investigate that route - I've bought an in-line fuse for the purpose.
Dave H
Apr 26, 2009 at 1:23 AM
DAVE H
  • 13,384 POSTS
It may even be easier to get to the rubber plug through the firewall for the accelerator cable !! just an afterthought ... !!
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_586.png
Apr 26, 2009 at 1:43 AM
