Transmission is experiencing rough shifting?
156,872 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
MGURULE16
A few months back my car threw a code that said, shift solenoid from 5 to 4 was malfunctioning. I stopped the car, turned it back on, and the code went away. I didn’t think too much of it, because the code never came back, and I didn’t hear, see, feel, or smell anything. However, yesterday I took the car over a mountain pass, and my car started to shift rough. The code also popped up again. We assumed that my transmission was low on fluid, so it overheated when I was taking it up the mountain. The car runs beautifully if i drive faster, but if I am just driving in town, it shifts a bit rough now.
Jul 5, 2023 at 10:40 AM
  • 110,251 POSTS
When you checked the fluid, was it low? Also, was it clean?
As far as the solenoid, that sounds like a downshift solenoid. So, if the vehicle needs to downshift, it may not happen. That could cause the transmission to overheat and can cause damage to the clutches.
Do me a favor. Let me know what code you found when you checked. Also, if possible, scan the can-bus. CAN stands for controller area network.
Basically, the different modules are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing them.
Here is a link that explains how it's done:
Jul 6, 2023 at 2:41 PM
