So the code list is long P0355, 351,353,356,352 and 335 which on the code reader it said camshaft sensor A malfunction but when you look it up in the internet it says crankshaft sensor. There were more code but those are the ones I wrote down. So before this the car was running fine. While driving the car I got a ESP malfunction then when I turned off the car it would not crank. I got multiple misfire codes and a camshaft sensor A malfunction code. I replace one of the 4 sensors not knowing at the time it had 4 sensors. When I changed the one sensor the car cranked and ran I was able to drive it home and while driving it ran smooth but when I came to an idle it was running rough. The car still runs rough and so I was trying to decide if I should replace the other 3 sensors plus the 4 solenoid adjusters, I also have a crankshaft sensor which I have not changed yet since the car cranked with the new camshaft sensor. Thanks
Sunday, February 21st, 2021 AT 7:41 PM
