Rough idle and smoke
2005 BMW 545I
155,000 MILES • 4.4L • V8 • 2WD • AUTOMATIC
NATHANIELDAVIDJAMES
I am having a rough idle and it seems to get rougher if I put it in reverse or park. I also have an all cylinder misfire and I have white smoke coming from the passenger side of the engine.
Oct 12, 2018 at 12:29 AM
  • 110,244 POSTS
The white smoke sounds like steam. Have you checked for a coolant leak?
Take a look through this link.
https://www.2carpros.com/articles/coolant-leak-symptoms
This link describes how to locate a leak.
https://www.2carpros.com/articles/radiator-pressure-test
Now, if all cylinders are misfiring, it sounds like you may have a head gasket issue or the intake manifold is leaking. Here is a link that describes how to check for a bad head gasket. Follow the directions and let me know what you find. Also, if possible, could you provide the trouble codes from the computer? If all cylinders are misfiring, the check engine light should be on. Thus, there will be trouble codes.
Check these few things and let me know what you find.
Oct 12, 2018 at 10:18 AM
